Autor Tema: INSTALACIÓN OFICIAL PARA VUELO DE CAMPAÑA  (Leído 291 veces)
  • Moderador
  • Usuario Héroe
    • Ver Perfil
« on: 01 de Mayo de 2020, 01:34:00 am »
Nota: la instalacion de este parche llevara la instalacion a BAT 3.8.3, indistintamente este o no activado el TOAS MOD en el JSGME
    Paso 1
    Cita
    Tener instalado IL2 1946 Sturmovik v 4.12.2
    ________________________________________________________________________________________________________________________________
    Paso 2
    Sobre la instalacion del Paso1 realizar una instalacion del BAT
    Cita
    DOWNLOAD THE BAT INSTALLER COMPONENTS:
    BAT v1.0 Setup.exe
    http://www.mediafire.com/?xs455g9cesbpuf5
    or
    http://www.sas1946.com/downloads/essentialsas/diverse/BAT_v1.0_Setup.exe
    BAT01:
    https://www.mediafire.com/?15bdhg7o2n7ifgy
    BAT02:
    https://www.mediafire.com/?qbr2v60oxpfc98v
    BAT03:
    https://www.mediafire.com/?o0b1ooxb43mi7a4
    BAT04:
    https://www.mediafire.com/?k22dsmvu6ar1mw2
    BAT05:
    https://www.mediafire.com/?db7ytuvtmk4u266
    BAT06:
    https://www.mediafire.com/?sh4r2w99hms252q
    BAT07:
    https://www.mediafire.com/?8zx5v5cs1kmw42u
    BAT08:
    https://www.mediafire.com/?2z819zbgbh4wjrr
    BAT09:
    https://www.mediafire.com/?az1eooc9p1qpl8d
    BAT10:
    https://www.mediafire.com/?v9a2y2z03psdlvo
    BAT11:
    https://www.mediafire.com/?1c0tn1uy4tfbl2e
    BAT12:
    https://www.mediafire.com/?oad46mioc3772ln
    BAT13:
    https://www.mediafire.com/?793axq1akmofa8q
    BAT14:
    https://www.mediafire.com/?tzxs1pk31ng18nd
    BAT15:
    https://www.mediafire.com/?y5cu7tkn1fzgefu
    BAT16:
    https://www.mediafire.com/?57yo7bkzowgl3iq
    BAT17
    https://www.mediafire.com/?65z476uzfovk76m
    BAT18:
    https://www.mediafire.com/?4z3ki23226aquv2
    BAT19:
    https://www.mediafire.com/?cjcjzix70zcdzqi
    BAT20:
    https://www.mediafire.com/?nj8xkjkr5ya734k
    BAT21:
    https://www.mediafire.com/?r5tad31ei0swjd6
    BAT22:
    https://www.mediafire.com/?jk9kjh1go12m5y7
    BAT23:
    https://www.mediafire.com/?o6x598t3vndj6bz
    BAT24:
    https://www.mediafire.com/?6ud4w3n3c1f8sl5
    BAT25:
    https://www.mediafire.com/?kmjqm62c6b2646g
    BAT26:
    https://www.mediafire.com/?kebgqhbs9gu3nap
    BAT27:
    https://www.mediafire.com/?yiyla3ay9of9jxh
    BAT28:
    https://www.mediafire.com/?e3tu7izujm16yhy
    BAT29:
    https://www.mediafire.com/?sjy3u1fs7bcc44t
    THE B.A.T. TORRENT FILE CONTAINS ALL 29 PARTS BAT01 TO BAT29:
    http://www.sas1946.com/downloads/essentialsas/diverse/BAT_v1.torrent
    PUT EACH OF THE PARTS (AS A COMPLETE ZIP), ALONG WITH BAT v1.0 SETUP.EXE, INTO THE SAME DESTINATION FOLDER ANYWHERE ON YOUR SYSTEM:
    RUN THE B.A.T. INSTALLER:  BAT v1.0 Setup.exe
    This is the base install.  The B.A.T. Expansion Packs very simply apply over the top of your B.A.T. install.  If you change your Mod folders you cannot apply the Expansion Packs until you revert them to their original state.
    DOWNLOADS - MEDIAFIRE - TORRENT - PA_DORE
    http://www.derrierloisirs.fr/il2/bdd2012/BAT.html
    Thanks to our good friend for this Mirror of all B.A.T. content.
    Paso 3
    Llevar al BAT a su version 3.8.2
    Cita
    BAT installation Order
    March 2020
    - BAT 3.0 Checkpoint Charlie
    - BAT 3.1 Sealion
    - BAT 3.2 Angels High
    - BAT 3.3 Pathfinder
    - BAT 3.4 Linebacker
    - BAT 3.5 Musketeer
    - BAT 3.6 The Blitz
    - BAT 3.7 Le Grand Cirque
    - BAT 3.8 Pegasus
    - BAT Patches 3.8.1  + 3.8.2
    always use the installer.exe.
    Paso 4
    Controlar que todo funciona
    • Confirme los valores del archivo conf.ini
    Cita
    CONF.ini
    Copying over your old one should do the trick.  Likewise your User folder for your previous keymapping.  CONF.ini needs to be right with B.A.T.  Here is an example with Sound setup properly and Graphics maxxed out.  If need be you can de-tune the graphics a bit, add texcompress etc, to speed it up.
    Here is a good thread explaining those settings;
    http://www.sas1946.com/main/index.php?topic=9756.0
    This part requires your own personal screen settings:
    [window]
    width=1440 - Whatever yours is
    height=900 - Whatever yours is
    • Revise true color (AVIONES ROSA)
    Cita
    HIGH DEFINITION DYNAMIC LINK LIBRARY - BATDLLS-01 OR BATDLLS-02?
    Described on Page-6 of the B.A.T. Manual - make sure you satisfy these conditions before proceeding.
    We have experienced different results with regard to the High-Res True Colour mod Dll’s, necessary for many of the newer mod features.
    The first set BATDLLS-01 is installed by default. The second set BATDLLS-02 will resolve issues for systems that do not get on with the first set: Simply UnZIP to your main Il2 Install and over-write.
    BATDLLS-01
    https://www.mediafire.com/?awq89quxr68ze9o
    BATDLLS-02
    https://www.mediafire.com/?T7gmf17wc0dvv55
    Make sure you have the right DLLs for the HD TRUE COLOUR MODS used in some areas.  There is no 'right' answer - Its BATDLLS-01 for some people and BATDLLS-02 for others.  Even within the Hangar-19 Test Crew we use different setups.
    The easiest way to check immediately: Launch The Jet Age and go look at the Hind helicopter in the QMB Preview Window.  If it looks normal you are good to go.  If its a hideous naked mole rat pink you need the other DLLs - Go Install BATDLLS-02.
    • Cargue la JetEra en el il2 Selector
    click sobre la imagen para ver mas grande
    [/list]
    Paso 5
    Descargar y colocar el TOAS MOD en la carpeta BATMODS que se encuentra en la raiz del juego
    Cita
    Well, here we go ... Once you have B.A.T. v3.7.2 or 3.8.1 installed and functioning properly, we can proceed to the installation of TOAS MOD ...
    STEP 1 - DOWNLOAD LINKS
    http://www.mediafire.com/file/qxmb9mtb2zsf6p7/TOAS_v2.7z.001/file
    http://www.mediafire.com/file/f9dp8uv69oeg5gs/TOAS_v2.7z.002/file
    http://www.mediafire.com/file/u0jfsltitn6a114/TOAS_v2.7z.003/file
    STEP 2 - DECOMPRESSION AND ACTIVATION OF MODS
    After downloading, unzip with 7z into the BATMODS folder of your BAT installation. It will result in 17 folders (mods). Next we will give an example of how they can be activated:
    #JTW_TOAS MOD
    #JTW_TOAS MOD_1982 MALVINAS
    #JTW_TOAS MOD_ALT COCKPIT C-130
    #JTW_TOAS MOD_ALT COCKPIT UH-1
    #JTW_TOAS MOD_ALT SA_MAP_v2
    #JTW_TOAS MOD_IA-58 DEFAULT SKIN (CAMO TYPE B)
    SNDMD-001_CMP_UJS_v1.23
    SNDMD-001_CMP_(#JTW)_PAL-COCKPIT SOUND
    #JTW_TOAS MOD_TANKSKYHAWK GREY CAMO FAA TEXTURE
    SNDMD-001_CMP_GUNS_&_EXP
    #BAT_00_NG-CAM_v1.6
    #BAT_00_NG-MAP_v3.0
    #BAT_00_NG-HUD_v3.2
    Paso 6
    Confirmar que el JSGME este sin Mods cargados
    DEBERIA VERSE COMO EN LA SIGUIENTE IMAGEN
    Paso 7
    Descargar Parche NUEVO
    Cita
    http://www.mediafire.com/file/x78f9ifbcxgfwi8/TOAS_MOD_v2.1.1.7z/file
    Paso 8
    Confirme que dentro de la carpeta #JTWE ubicada en la Raíz se vea como la siguiente imagen. Eliminé las carpetas que sobran.
    Descomprimir el parche nuevo y poner todas las carpetas en la raiz del juego, sobrescribir todo
    Paso 9
    Cargar el TOAS mod en el JSGME Aconsejo usar el Perfil provisto aqui abajo
    Cita
    We leave here the .mep file that you can use with JSGME to load these mods automatically. Simply download this file and place it in the BATMODS folder (or the one you prefer). Finally, click on the "Load Mod Profile" tab of the JSGME, find the .mep file and load it. The process will take a few minutes depending on the speed of your computer.
    http://www.mediafire.com/file/ltr3vqybg4h444m/TOAS_MOD_OP1.mep/file
    NOTE: THE ONLY MODS NEEDED TO EXECUTE TOAS MOD ARE #JTW_TOAS MOD and #JTW_TOAS MOD_1982 MALVINAS, THE OTHERS ARE PURELY OPTIONAL.
    Pasos para activarlo (según donde hayas descargado el archivo perfil)
    Seguramente aparezca el mensaje que el JSGME no responda....DEJELO TRABAJAR TRANQUILO, esta moviendo toneladas de informacion.
    Cuando termine se vera de la siguiente forma!
    LISTO!
    « Última Modificación: 01 de Mayo de 2020, 06:05:28 pm por GAE_Chape »
    • Moderador
    • Usuario Héroe
      • Ver Perfil
    Re:INSTALACIÓN OFICIAL PARA VUELO DE CAMPAÑA
    « Respuesta #1 on: 01 de Mayo de 2020, 01:36:39 am »
    Estoy Subiendo el Parche TOAS.
    Estoy armando el POST, creo que hoy ya subo el parche!
    Estoy armando imagenes para hacer una guia mas entendible
    IMPORTANTE
    Personal del GAEv con la instalacion ya realizada del BAT aplicar desde el Paso 6
    « Última Modificación: 01 de Mayo de 2020, 06:01:48 pm por GAE_Chape »
